Re: H Water pump
Posted by Nebraska Kirk on June 06, 2014 at 09:37:37 from (207.91.4.159):
In Reply to: H Water pump posted by VeryOldJack on June 06, 2014 at 06:52:15:
I see no problem with making your own studs out of a bolt, cut the head off and use a jam nut to tighten against the fan. You don't need grade 8, 5 or 2 will work fine. I am with you on the spring solution, why spend $6 on one when you can get them for 75 cents? It is not high tech or an extreme duty spring.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
