Re: H Water pump
Posted by Owen Aaland on June 06, 2014 at 16:49:54 from (216.47.33.5):
In Reply to: H Water pump posted by wayne in mn on June 06, 2014 at 10:12:09:
The impeller does not do any sealing like what is common on most pumps. The springs only need to keep the impeller from moving back and rubbing on the engine block. The sealing is done by the shaft packing.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
