Re: H Water pump
Posted by wayne in mn on June 06, 2014 at 10:12:09 from (66.188.174.211):
In Reply to: H Water pump posted by VeryOldJack on June 06, 2014 at 06:52:15:
The springs have to be strong enough to maintain a
seal on the shaft to impeller when in use.(they pull
the impeller towards the radiator)
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
