Re: 806 gas fuel tank
Posted by Jim Naden on June 07, 2014 at 03:06:32 from (70.198.66.131):
In Reply to: 806 gas fuel tank posted by lee little on June 06, 2014 at 19:41:48:
There is a stand pipe incorporated in the sediment bowl inlet fitting. No screen on the inlet pipe. Evidently the tank is contaminated with debris.
A thorough cleaning is in order. Best procedure would be to remove the tank but it is possible to clean one on the tractor if you don't mind the mess.
If a full flow of fuel is available from the tank an electric pump should not be necessary.
