Re: Farmall 300 temperature gauge help
Posted by rustyfarmall on June 10, 2014 at 06:44:00 from (208.126.186.41):
In Reply to: Farmall 300 temperature gauge help posted by Garson on June 10, 2014 at 06:19:33:
There is a special adapter that screws into the head, and then the gauge screws into that adapter. The "tee" fitting that you removed was probably installed by a previous owner to allow for an electric "tank type" engine heater. If you can find the tee fitting, you might want to put it back on.
Incidently, that special adapter that screws into the head is still available from Case-IH.
