I timed it #1 on TDC one next to radiator. I have fire to all plugs. Have plug wires as suggested. I found another timing procedure yesterday. Put #1 at TDC them put ohm meter between the wire going from the side of the distributor to the coil the other end to ground, turn the distributor until the points just open. This seem to work. The tractor started for few seconds and then quite. I'm working on fuel now. If I can the choke set right, think it will run. Thank you for your help!!
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
