Re: 1953 Cub Want Start
Posted by El Toro on June 10, 2014 at 13:45:09 from (96.244.7.206):
In Reply to: 1953 Cub Want Start posted by Gary McArdle on June 10, 2014 at 11:59:15:
Did you time the No1 piston near the radiator on the compression stroke? Do a compression check and post your readings. If you have a distributor make sure you're getting battery voltage to your coil. Pull off a plug wire and hold it about 1/4" away from the plug while a helper make an attempt to start the engine. Should see a hot spark from the plug wire. Do you have your plug wires in the correct firing order on the distributor cap? Should be in this firing order. Hal
2-1
4-3 As the rotor rotates Clockwise.
