Posted by SW EM on June 13, 2014 at 07:14:12 from (166.181.3.203):
Should piston pins be able to turn in the pistons as well as in the rod bushings? I"m assembling my new 400 Tisco kit and only one piston had the pin go in solid and not turn when the rod was moved. Is this normal?
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
