Re: Quick engine overhaul question
Posted by Owen Aaland on June 13, 2014 at 07:34:20 from (216.47.33.5):
In Reply to: Quick engine overhaul question posted by SW EM on June 13, 2014 at 07:14:12:
At room temperature the pin clearance should be .0001 - .0002 inches. At that clearance the pin should slowly slide through the rod bushing when held vertical and lubed with 30 weight oil. With aluminum pistons the pin clearance will become an interference fit as the temperature drops.
