ihc 4586 dash consel tell tale lites
Posted by jim_cloverleaf on June 13, 2014 at 09:54:53 from (24.213.206.167):
ihc 4586 will not start. neutral safety switch bad. by passed and have audible alarm and one indicator tell tale lite on. have oper manual. wiring diagram not correct. no tell tale pics.
it is either oil pressure, coolant level or diff level. have checked all and levels ok. so now I will check each sensor. no tests instructions for them in service manual. what ohm reading is correct ? then I check power cab relay and starter relay. any pics of tell tale would be appreciated.
