Re: 424 End loader hydraulic connection
Posted by jimb2 on June 21, 2014 at 16:41:11 from (99.240.243.222):
In Reply to: 424 End loader hydraulic connection posted by 417Dutch on June 21, 2014 at 11:27:27:
Hi 417Ducth, your 424 should have similar
hydraulics as B-414,434,444,384, etc.
From archives:
Hi Ben, the B414 remote outlet that can be
controlled by 3pt lever is only single action and
a loader bucket requires a double acting cylinder.
The proper way to hook up a loader on a B414 is to
buy a set of hydraulic control valves, mount then
on the loader frame by the right side of the
steering wheel. Cut a section out of the high
pressure line from the hydraulic pump and connect
this line to inlet of hydraulic control valves,
connected outlet of hydraulic control valves to
remaining section of the high pressure line that
goes to the hydraulic reservoir under the seat. If
the hydraulic control valves have a low pressure
dump line connect this line into the hydraulic
filler plug behind the seat.
Hope this helps
JimB
