Re: 424 End loader hydraulic connection
Posted by 417Dutch on June 22, 2014 at 11:05:39 from (70.195.5.232):
In Reply to: 424 End loader hydraulic connection posted by jimb2 on June 21, 2014 at 16:41:11:
Below is what I had conveyed to Owen who also responded. As far as what you had sent me I had a local individual tell me the same thing. However, he was not familiar with the workings of the flow divider and I was wanting to be sure that I was not overlooking something. It would be great if I could see a hydraulic flow diagram for this valve so I could make sure that having the loader hooked up to it is in fact the main problem.
Thanks,
Dutch
Owen, thanks. Quiet frankly the loader is already on the tractor and has a open center control valve with relief already on it. I recently bought the tractor and the loader operates slowly and does not have the lifting capacity that it should. The tractor has power steering and the hydyraulic supply line for the loadder is attached to a port on the flow divider for the power steering. The return line for the loader attaches to a port on the front plate just below the seat. The power steering and the 3 point work just fine.
