Re: Re: Farmall H Manifold Bolt Holes Stripped....Need Help...Over!
Posted by Wayne W on December 27, 2000 at 15:37:21 from (165.247.17.102):
In Reply to: Re: Farmall H Manifold Bolt Holes Stripped....Need Help...Over! posted by Andy Martin on December 27, 2000 at 15:20:38:
Check out MSC (Machinshop Supply Co). They have several types of Helicoil products. Their phone to place an order is 1-800-645-7270. They have a Tech support group, but I cannot find their number right now. They have about a dozen pages of thread repair products.
You can also pull up their catalog via www.mscdirect.com
If you've broken that stud off to close to the block to weld the nut on, as previously suggested, contact your local machine shops and find one that has an Electrical Discharge machining device. Those things will get that stud out, slicker'n snot!
Post A Followup
: Re: Re: Re: Farmall H Manifold Bolt Holes Stripped....Need Help...Over!
