Posted by ken house on June 23, 2014 at 14:19:59 from (173.242.241.201):
In Reply to: 140 farmall posted by Surphn on June 23, 2014 at 12:45:22:
kinda hard to explain. there are 2 rods from tractor to part that holds cultivator shanks. the top rod , is the adjustment. there should be a part that is forked, it has a pin in it , remove the pin and the cultivator will lower to the ground. the piece that is forked is threaded. clockwise, looking at the end of it, should shorten the rod and raise the cultivator. DO NOT PUT A BAR INTO THE FORK , use a pipe wrench to turn the part.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
