Re: 140 farmall
Posted by Surphn on June 24, 2014 at 06:29:03 from (96.10.218.52):
In Reply to: Re: 140 farmall posted by ken house on June 23, 2014 at 14:19:59:
Thank you! I looked at that part you mention and started to turn it, but was afraid I would create more problems than I already had. IF I remember , that part had a nut behind the fork, so I assume it is backed off and the fork can be turned in a few turns then tighten the nut back up against it.
