Re: 574 Clutch Adjustment
Posted by 60 acre hillside on June 24, 2014 at 04:37:54 from (69.35.211.56):
In Reply to: Re: 574 Clutch Adjustment posted by caterpillar guy on June 23, 2014 at 20:00:14:
I unhooked the linkage and there is no freeplay at the lever coming out of the clutch housing. I was hoping that the fingers could be set away from the bearing.
