key on, starter motor not engaged; in this mode you should only have current flow if the points are closed. The R terminal on the starter; when starter is not engaged it should be a dead terminal, no voltage & no continuity to ground, when starter is engaged it should be 12 volts (resister by-pass) for starting
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
