Re: Capping hydraulic lines
Posted by Wardner on December 27, 2000 at 20:21:34 from (63.23.215.32):
In Reply to: Capping hydraulic lines posted by Sam on December 27, 2000 at 18:41:04:
You might be able to find a fitting with a compression ferrule and nut on one side and pipe thread on the other end. Heavy duty steel fittings are made for hydraulic service. You probably only need brass because the circuit is not being used and not under pressure.
Post A Followup
: Re: Re: Capping hydraulic lines
