Re: Farmall H Transmission Pilot Bearing Again
Posted by D Slater on June 27, 2014 at 03:46:35 from (184.14.170.196):
In Reply to: Farmall H Transmission Pilot Bearing Again posted by mtjohnso on June 26, 2014 at 19:50:52:
Serial # up to 391357 uses bearing 43356DA. Serial # 391358 and higher uses the bearing the dealer sold you. 98 % chance you have a tractor below 391358. 43356DA is still available unless a recent discontinue part.
