Farmall H Transmission Pilot Bearing Again
Posted by mtjohnso on June 26, 2014 at 19:50:52 from (72.171.16.60):
When I ordered a new Pilot Bearing for the main shaft in the transmission, they send me P/N 358035R91. It had the correct O.D and I.D but was 0.810 wide whereas the original was 0.600 wide. This causes interference problems when the front input shaft is installed over the pilot bearing. Interference meaning that the front input shaft will not turn freely independent of the main shaft.
Called Case IH and they said all available parts for the H pilot bearing were all the same width.
Anyone else run into this problem?
Am I doing something wrong?
