Re: Farmall H Transmission Pilot Bearing Again
Posted by Eastsider on June 27, 2014 at 06:19:44 from (24.111.75.41):
In Reply to: Farmall H Transmission Pilot Bearing Again posted by mtjohnso on June 26, 2014 at 19:50:52:
Yes, that is exactly what I mentioned earlier when you asked about the star washer. The bearing you need is still available, but you need to bring in your serial number or make sure they order the older bearing. I just repaired my tractor and they had put in the incorrect bearing...it was a mess! Do not use it!
