Re: Farmall 806 propane problems
Posted by Bob M on June 29, 2014 at 20:20:11 from (74.67.188.246):
In Reply to: Farmall 806 propane problems posted by avant tractor on June 29, 2014 at 19:52:07:
I have a Super H with similar issues. After sitting idle for 10 - 11 months it absolutely refuses to start despite good spark, fresh gas, etc. However a squirt of motor oil (or blast of WD-40) into each hole will get it to start right up, then run fine once the smoke clears. And as long as it's started every few weeks afterward it starts easily.
All I can figure is it loses compression due to dry cylinder walls from long periods of sitting. A bit of oil to wet the rings is all it needs to get compression back following a long layoff.
