Re: Farmall 706 - 2250 Loader Pressure
Posted by mkirsch on June 30, 2014 at 07:31:18 from (65.199.189.6):
In Reply to: Farmall 706 - 2250 Loader Pressure posted by Matt Tieken on June 30, 2014 at 05:50:48:
GPM has *NOTHING* to do with lift capacity.
PSI is what gives you your lift capacity, but you can't "adjust" the problem away. As stated before the relief valve is non-adjustable.
1450PSI should be more than enough to lift whatever you can safely lift with that loader, so odds are you aren't even making that much pressure.
I second getting a pressure gauge and checking the current status of the tractor's hydraulic system.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
