Re: Farmall 706 - 2250 Loader Pressure
Posted by caterpillar guy on June 30, 2014 at 18:37:13 from (24.247.200.73):
In Reply to: Farmall 706 - 2250 Loader Pressure posted by Matt Tieken on June 30, 2014 at 05:50:48:
A power beyond would be my bet. Then the external valve could be plumbed into that line so you would still have your SCV out the back. Then by checking you pressure and correcting you will lift all you can carry safely.
Today's Featured Article - Converting from 6 Volt to 12 Volt - by Chris Pratt. It's a common problem for old machines especially when the weather starts to dip below 40 and the tractor isn't fired up as often. You are probably used to the 12 volt Diehard, charged with 200 amp alternator of your 3/4 ton that always is ready and always starts. It's this type of experience that brings about the many queries we get for 12-volt conversion kits. Since only a few kits are available (we sell kits for the ... [Read Article]
