Generator and Voltage Regulator for an H
Posted by Jeff Pfeiffer on July 01, 2014 at 06:22:02 from (69.95.13.99):
I have a 1950 H which seems to have a mix of original and newer wiring. The generator is a Delco-Remy 1101355 and the cut-off relay is a Delco-Remy 1116766. It's still wired for 6V, uses a positive ground and has a magneto.
Since I'm not ready for a restoration (that's in the future sometime), I'm considering a simple re-wire job just to get the electrical system back up and running.
When I compare the tractor's current wiring to the generator and cut-off relay, it doesn't seem to match what I'm seeing published.
third party image
third party image
It's a little tough, from the pictures, you can see that the 2 wires coming from the electrical box are landed on the F terminal of the generator and BAT of the cut-off relay. There is also a wire from the A terminal to the GEN terminal. BUT, there's also a wire from the F terminal on the generator to the F terminal of the cut-off. Why? Remove this?
