Re: 460 smokes a lot
Posted by Ron in Can on July 03, 2014 at 08:25:21 from (208.114.152.153):
In Reply to: 460 smokes a lot posted by Hugh McKinney on July 03, 2014 at 08:09:58:
the actual number for compression is not that important as thee difference between the cyl and yours sounds not too bad you might have to " go into the short block " as it sounds like the oil rings are stuck they don't hurt or help compression numbers but they keep the oil out of the exhaust which yours is not. I hope this helps.
