460 smokes a lot
Posted by Hugh McKinney on July 03, 2014 at 08:09:58 from (173.202.172.156):
Got the 460 LP running last weekend, runs really well, except that it smokes and even blows out small amounts of oil out of the exhaust! I checked compression on all cylinders, it ranges from about 90 to 130 psi. Could anyone tell me what they typically get in psi on 460's or 560's when they check for compression pressure? I sure do hate to go into the short-block, may start with checking for missing or broken valve stem seals. Anything in particular to look out for on a preliminary inspection of the heads and cylinders? Thanks, Hugh
