Re: Super A Left Rear wheel heating
Posted by mkirsch on July 03, 2014 at 11:14:01 from (65.199.189.6):
In Reply to: Super A Left Rear wheel heating posted by Tim Pazda on July 03, 2014 at 06:57:05:
The brake drum is nowhere near the fluid on a Super A. It's up on the axle at the top of the final drive, while the fluid is down below in the pan at the bottom of the final drive.
You would have noticed a burning brake smell long before the heat transferred all the way down.
I would recommend that you drop the oil pan off the final drive and see what you have going on in there. It's not a major job, and at least you'll know instead of guessing.
