The brake is next to the tranny on the diff shaft not on the axle and if the seal is leaking out of the tranny it sure will get into the brake drum and fluid will leak out the weep hole in the final. Axle in final wouldnt get hot driving down the road unless the bearing would be shot then it would make a terible noise as the gears would not in line up.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
