Re: Cub Lo-Boy 154
Posted by Lynn Patrick on July 04, 2014 at 09:37:06 from (208.68.113.24):
In Reply to: Cub Lo-Boy 154 posted by Lynn Patrick on July 04, 2014 at 08:15:53:
Charlie,
I have the plugs out.
It will only turn a very few degrees by hand, and will only turn w/the starter if I back it off those few degrees first, then only back to where I started. I tried rocking it in 3rd gear but still couldn't turn it more than the same.
