Re: Cub Lo-Boy 154
Posted by CharlieNJ on July 04, 2014 at 09:53:23 from (76.117.68.151):
In Reply to: Re: Cub Lo-Boy 154 posted by Lynn Patrick on July 04, 2014 at 09:37:06:
Hmmmm, that's not good, I wonder if the hydraulic pump could be eating some metal? Other than that, the next step might be to drain the oil, and look for metal, then the oil filter, and look for metal. Did all the plugs look good? She didn't swallow a valve did she?
