Posted by Lynn Patrick on July 04, 2014 at 13:36:07 from (208.68.113.24):
In Reply to: Cub Lo-Boy 154 posted by Lynn Patrick on July 04, 2014 at 08:15:53:
Okay. I pulled the pan & found a few small pieces of metal. Can't tell where they came from. There is a small stove bolt & lock washer - like is used to hold a condenser in the distributer. A couple very small pieces broke off of something, & 2 small steel balls about the size of BBs. Is there any small ball bearing in the governor? And could governor pieces end up in the pan? And the only way that rod cap bearing got in there was it had to have been left there!
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
