Re: Cub Lo-Boy 154
Posted by CharlieNJ on July 04, 2014 at 15:34:00 from (76.117.68.151):
In Reply to: Re: Cub Lo-Boy 154 posted by Lynn Patrick on July 04, 2014 at 13:36:07:
Lynn, there is a thrust bearing in the governor, those ball bearings are about that size. That bearing is lubed by engine oil, so I suppose it could end up in the pan. I don't know where the stove bolt could come from, but heck, you've found a bearing shell in there too. Might want to check the governor. But looks like you'll be doing an overhaul, not the best time of year for that.
