Posted by bja105 on July 06, 2014 at 08:27:19 from (174.130.31.127):
In Reply to: Farmall M, no spark posted by bja105 on July 05, 2014 at 19:09:39:
Ok , I adjusted the points and have it running. I loosened the screw, and the spring moved it. I tried it a few different places, and it runs best where I left it, but still misses at high rpm. Is this a trial and error thing, or is there a specific dimension I should be setting the points to?
I want to replace the spark plugs, since they are pretty carboned, should I replace the distributor cap, rotor, points, and condenser as a maintenance item, or wait until they quit?
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
