So, adjusting the points so they open and closed as I suggested fixed it yayyyyyyyyyyyyyyy Congratulations
"Is this a trial and error thing, or is there a specific dimension I should be setting the points to?"
YES they set at a specified gap (range of around 0.016 to 0.025 or so depending on cylinders and engine), but I don't have the tune up figures in front of me.
"I want to replace the spark plugs, since they are pretty carboned, should I replace the distributor cap, rotor, points, and condenser as a maintenance item, or wait until they quit?"
If the points are pitted or burned or carboned Id DEFINITELY replace them,,,,,,,,,If the cap and rotor are okay, look good and clean with no cracks or carbon traces I wouldnt necessarily change them.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
