Posted by John M on July 06, 2014 at 15:43:09 from (209.213.28.157):
In Reply to: Farmall M, no spark posted by bja105 on July 05, 2014 at 19:09:39:
Need new points. Those are shot. You set the points by getting the rubbing block on the high part of the square shaft. (turn the engine over to do this.) Move the other piece until you can get a little resistance, setting is .020, on your feeler gauge.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
