Posted by bja105 on July 06, 2014 at 17:38:20 from (71.60.105.123):
In Reply to: Farmall M, no spark posted by John M on July 06, 2014 at 15:43:09:
How do I turn the engine while doing this? With three of the four plugs in I couldn't turn it by hand, but I didn't try that hard.I'll be changing plugs anyway, I'll try it with them all out. There is also a place I can get a pipe wrench on the front of the crank shaft.
If I am doing plugs and points, should I do the rotor, cap, and coil, or is that risking getting Chinese junk worse than the old ones?
Can I get new ends to the plug wires so I can shorten the existing, or do I need all new?
Are most of these things available at NAPA?
Thanks everyone. You folks are making me look smart!
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
