Posted by Mark Robke on July 06, 2014 at 16:21:32 from (71.31.17.252):
In Reply to: Stuck In Reverse posted by famousfather on July 06, 2014 at 13:53:20:
Pull the shift lever housing off, line up the 'neutral gate' so all shift rails are in line and drop your shifter back in so it goes in the neutral gate. Once you take it out you will see how it works,very simple.What most likely has happened your shift lever finger on bottom of lever is worn and slipped over or thru the shift rails. Be careful when you lift the lever out, there are detent balls under the springs, don't let the springs come up out of their holes. Mark
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
