Posted by famousfather on July 07, 2014 at 15:14:52 from (75.133.49.203):
In Reply to: Re: Stuck In Reverse posted by Mark Robke on July 06, 2014 at 16:21:32:
Thanks for your solution to my tractor stuck problem, Mark. Pulled the shifter & housing off, lined the rails up properly and dropped the shifter back in and yes, the bottom of the shifter is badly worn/rounded off. Crossed my fingers and started it up and it all shifted properly; neutral, reverse and forward gears. Will have to find another and replace or I'll be "lining up rails" more often than I'd like. Was surprised at the amount of spring pressure on the housing but was careful as you suggested and didn't lose any springs. Thank you again for your prompt help!
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
