Posted by Ed Hotaling on July 06, 2014 at 18:12:18 from (67.240.55.230):
In Reply to: SA Loader Problem posted by Doug Kieta on July 06, 2014 at 15:11:17:
My first thoughts re either the cylinder or the valve. I have had cylinders stat to leak internally when the seal gets worn or the nut holding the piston on the end of the shaft works loose. The valve could be leaking internally as well. If the cylinder is repairable, it is fairly easy (messy, but easy) to open it up and inspect. If it is welded together, you are skunked on that one. The valve would be a bit more of a job.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
