Re: SA Loader Problem
Posted by Brendon-KS on July 07, 2014 at 04:12:52 from (63.245.147.52):
In Reply to: Re: SA Loader Problem posted by Ed Hotaling on July 06, 2014 at 18:12:18:
According to an old sales brochure I have the 1000 was only available with a single-acting lift cylinder. On this kind of cylinder an internal leak basically means an external leak so you should be able to tell if that is the problem unless your loader has been updated with a double-acting cylinder. You could also install a reliable shut-off valve in the hose between the spool valve and cylinder. After raising the loader and shutting the valve note what happens. If the loader stays up, your problem is in the spool valve. If it still creeps down your problem is in the cylinder.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
