Posted by pete_5959 on July 08, 2014 at 04:12:03 from (138.162.128.53):
In Reply to: H: Rusty Fuel Tank posted by Sapper55 on July 07, 2014 at 20:40:34:
Sap..Pull the tank off and drop in a bunch of washers and hex nuts/bolts. rolled it around or strap to a nother tractor rear tire and drive around a bit. I usually remove the hardware then fill with a water/muriatic acid mix and let set for 30 minutes or so. Drain and rinse thoroughly. Add a box of baking soda when rinsing to neutralize the acid. Use a hair dryer to dry inside of tank. Also use a 3-4" piece of straight copper hose inserted in your fuel sediment bowl inlet. You will not have any more issues....
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
