Re: F400G: Throttle Will Not Respond at Low Setting
Posted by T_Bone on December 28, 2000 at 20:19:42 from (207.254.53.123):
In Reply to: F400G: Throttle Will Not Respond at Low Setting posted by Lar on December 28, 2000 at 20:06:05:
Hi Lar, You should be able to see the governor rod on the carburator move when the lever is moved to low setting. If not check for binding of the linkage, unhook linkage at carb and see if you can push it closed, if not then rebuild carb.
T_Bone
Post A Followup
: Re: Re: F400G: Throttle Will Not Respond at Low Setting
