Follow-up question on 460 hydraulics
Posted by Hugh McKinney on July 10, 2014 at 08:33:14 from (99.195.94.74):
Per my previous question about the hydraulic pump apparently not turning on my 460 (with Independent PTO), I have observed that the drive gear that turns whenever the engine is running, is offset so that the gear's teeth are nearer to the front of the tractor rather than the other way around....is that the correct arrangement? It appears that the teeth aren't even contacting one another...that the drive and driven gears are not even coming into contact with one another...could that drive gear be on there backwards? Thanks again, Hugh.
