Posted by Zach Scherf on July 10, 2014 at 17:35:04 from (68.57.200.77):
After doing some ta work last fall(split the tractor twice, replaced most bearings, and the ta clutch and clutch disc) my ta is still not working properly. The ta works fine on the low side. However if you put the ta forward the speed doesn't change at all. The tractor just keeps moving at the same speed. There is no noticeable sign that anything happens when I throw it forward. Also, another issue I have with it is it bogs the tractor down when I use the hydraulic remotes, but not the three point. At idle they are very slow and often don't move a cylinder unless I up the throttle. Another thing is when using a one way cylinder when I set it down it blows fluid out if the remote not being used. Any ideas as to what could be wrong? Have a small farm around. 200 acres want to get the ole girl more involved but need to address these things first Thanks zach
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
