Posted by Janicholson on July 11, 2014 at 04:24:27 from (71.194.207.139):
In Reply to: Farmall 656 t/a posted by Zach Scherf on July 10, 2014 at 17:35:04:
The TA could de operating in either direct, or reduction. If the TA clutch is properly adjusted so the throwout bearing has the correct clearance with the lever forward, and when pulled back, releases the disk, it should be operating. If it will roll forward on a level smooth surface in gear with the TA back, and your foot off the clutch, the TA is in low. if it will still roll forward with the TA lever forward, the TA clutch is not locking the TA into a direct drive condition. If it will not roll freely with it back, and the TA clutch is released, the TA gears may be jammed,(or welded together by a former owner). Jim
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
