Re: I 560 D with over center PTO clutch
Posted by pete 23 on July 10, 2014 at 18:51:38 from (74.33.72.212):
In Reply to: I 560 D with over center PTO clutch posted by Darald on July 10, 2014 at 16:33:02:
I can not see a good reason for it not to lock in the shut off position unless the rod is totally out of adjustment. You do realize the lever does not lock in the engaged position, right. The lever just floats. I have seen some people adjust the linkage so lever locks when engaged and in that case the lever will be totally out of wack in the disengaged position. It should have about half inch or 5/8th inch of tension in shut off. In other words, you feel the internal brake compress the springs inside when the pawl is that far from the notch toward disengage. Also, nice snap when going over center to engage.
