Re: I 560 D with over center PTO clutch
Posted by Darald on July 10, 2014 at 20:08:11 from (206.163.229.236):
In Reply to: Re: I 560 D with over center PTO clutch posted by pete 23 on July 10, 2014 at 18:51:38:
Everything seems to work as it should, just before lock position you can feel the compression and the pto stops. There is a snap but not like I would expect from using other over center clutches. The button and rod seem to work correctly, I have had them apart and cleaned the rod and channel; after looking tonight I may have to cut the notch for the lock deeper. Thanks for the reply.
