Posted by thephantompatriot on July 13, 2014 at 11:32:22 from (24.112.147.17):
I just bought an IH 354 (gas) a few weeks ago. I am new to tractors but my father in law is helping me fix it up, he's an auto mechanic and has worked on tractors since he was a teenager. The 354 is in decent shape but obviously a 40 year old tractor will require work here and there.
The tractor was used for grading PA State Highways, came with a box blade on it and turf tires in the front. The first thing we did was flip the rear wheels and bring in the front axle to line up the front with the rear. (I plan on using this tractor for mowing w/ a 5' Land Pride RCR1860 as well as having a snow blade for winter).
Anyhow, the camber before moving the front in seemed fine, but once moving the front axle in the driver side wheel camber is noticeably different than the passenger, I would say probably twice the angle of the passenger. When I take my hand off the wheel it pulls to the left. I know the toe angle is slightly off from when we adjusted the axle, if that makes a difference or not. It was worse before we repacked the wheel bearings. We talked to an old timer and he said he thinks it's the spindles or the spindle bearings, does anyone have any other suggestions?
Also another issue I have is the throttle lever stays in position when it's set to a slow/medium speed, but if you crank the throttle down to high it seems to vibrate itself loose back to the medium range. What do I have to do to make the throttle lever stick in the high position?
Thanks.
PS- Here are a few videos of the actual tractor I bought, posted by the seller:
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea
... [Read Article]
Latest Ad:
[More Ads]
