Posted by jimb2 on July 13, 2014 at 12:40:21 from (99.240.243.222):
In Reply to: IH 354 Questions posted by thephantompatriot on July 13, 2014 at 11:32:22:
Hi, re throttle lever, there should be a nut under the dash to tighten against a friction disk. See: http://partstore.caseih.com/us/parts- search.html#epc::mr52549ar961430
Re camber, see parts at: http://partstore.caseih.com/us/parts- search.html#epc::mr52549ar962690
First check front hub to axle bearing wear by jacking front axle until wheel is clear of ground, grab top and bottom of tire and try wiggling in back and forth and see how much play is in the axle bearings. Next lower the jack and watch the clearance between top of tire and spindle. If the gap closes too much the spindle bushings are worn. Operators forget that doing regular grease maintenance goes a long way to preventing wear. The front axle bearings and races are susceptible to water getting in around the inner hub seal.
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea
... [Read Article]
Latest Ad:
[More Ads]
